3. A7NETH-2P parameters setting
Use A7NETH-2P Instruction manual to prepare instalation of the communication option board. Interracting with the system can be performed via USB (Using a mini-B USB cable).
- The manual presents an example of data format
- The manual presents a list of control and status word that can be used to transfer data between PLC and INV
- The manual presents a detailed list of each bit in the control and status word
With this information you can proceed to set the card parameter using Mitsubishi Configurator studio
- First Double click on A7NETH-2P [1.1.25]
- In Project Tree we can see summary of actual set parameters
- There is option to restore factory settings of card parameters
- After restoring factory settings or the first time you start a new card, select the card model
- Ethernet option
- CCLink IEF Basic communication type
- Set Network configuration
- Option card allows to set two types of send parameters
Produced I/O Data – INV -> PLC
Consumed I/O Data – PLC -> INV
- Produced and consumed data are word type data
- Selecting the parameter causes the appearance of warning
Each parameter that we want to use and was described in the tables from the documentation must be set. For example we will use 2 produced data words ( Inverter status – register nb 100 and Output frequency – register nb 201) also we well use 2 consumed data words (Command register – register nb 1 and Command frequency RAM – register nb 2)
- Produced data words settings
- We perform the same procedure for Consumed I/O data
- Consumed data words setting
- The result of these operation
- Download Configuration and reset the card
4. INV parameter settings
- The manual presents a detailed list of Inverter parameters that need to be used to transfer data between PLC and INV
- Example of parameters (After setting the network parameters in the card, the network parameters in the inverter should be updated automatically).
5. Diagnostics
6. Example of program
Data transfer PLC->INV
W101 - Command Frequency RAM (20Hz)
W100 - Command Register b1. Forward Rotation Command
In Mitsubishi Configurator Studio there is opportunity to monitor command register
Data transfer INV->PLC
W1 - Output Frequency (20Hz)
W0 - Status Register b0.RUN, b1.FWD, b3.SU, b6.FU
In Mitsubishi Configurator Studio there is opportunity to monitor status register
7. Attachments:
File name: | Description:
iQ-F.gx3 | File with PLC program/configuration
Project1.mscproj
E720.frc2
| Flie with A7NETH-2P configuration
Flie with FR-E700 configuration
