Summary: this document describes how to convert existing GT designer project to Iconics GraphWorX files
Launch GENESIS64 Converter-GOT from Windows Start > ICONICS Tools, specify
your GTX project file and fill in a few other settings. The tool will produce one or more
GraphWorX64 display files (GDFX) and, if necessary, a CSV file that can be imported into
the Mitsubishi Electric FA Connector.
Select the file to conver
If project has more than one screen, select which of existing screens you want to convert
After execution of operation open created file and check if result satisfies you
If not, make the necessary changes manually
