This is an universal solution describing how to send actual error code or other data from robot all the time (even if robot is in Error State).
This solution uses State Variable, Multitasking function and program set in Always (permanent) mode.
Define a separate program which will be performed independently in Always mode. In example below program name is: DATA
In the program use desired rewriting to outputs. For example in order to rewrite actual robot's error code, a special M_ErrNo state variable is used. In this case the value is written to CC-Link network (6000 outputs area).
If the same manner the other important data can be sent from robot all the time.
Register selected program in an order below
1 Open Slot Table paremeters
2 Select one spare slot (with no program name)
3 Click Set… and confirm next window about reading program list
4 In Slot Table Parameter Setting chose desired program
5 Set condition to ALWAYS
6 Write parameters and restart robot
After restarting the robot the program will run.
If there is a need to make changes in a program which already works in Always mode, the special stopping procedure must be run.
1 Open Slot Run State in a Monitor tab
2 Click Stop All Program button
Now all programs are stopped and can be opened and edited.
