MX controllers (MX-F, MX-R) and GOT3000 - Encrypted communication between PLC and HMI
This article describes how to establish an encrypted connection via Ethernet between GOT3000 and MX-F or MX-R controller
Hardware configuration
- GOT3000 as client
- MX-F / MX-R as server
- PC with GT Designer3 and GX Works3 software
Setting procedure
The setting procedure is described in the attached PDF document "MXR_and_GOT3000_Secure_Communication.pdf". This procedure is the same for MX-F and MX-R.
If there is no client certificate in the GOT Utility Setup, please enter data in the GT Designer3: GOT Setting > Environmental Setting > Information Protection Setting > Certificate
If a .DER extension of the certificate file is necessary for the server in GX Works3, you can change the extension from .CER to .DER.
