FAG SmartCheck ethernet connection to Q PLC
Smart Check -FAG - ethernet connection to Q PLC
This project submit configuration of ethernet connection between Q PLC and SmartCheck.
Q settings
Select "MC Protocol" and the port number if you are communicating with the built-in port. SmartCheck can communicate via TCP and UDP.
Restricted ports list:
In addition, it is necessary to select the possibility of changing the values of registers online:
When using the QJ71E71 Ethernet module, set in the Open Setting tab:
Fixed Buffer -> Send / Receive setting does not matter in this case.
In addition, in the "Operation Setting" tab, select:
FAG SmartCheck settings
Add device.
After the IP address and port number setting, you can check the communication by pressing the "Connection test" button.
Reading register from the controller, example of speed reading from register D100.
In the above window, you can scale the value, set the unit, and set the reading interval.
Checking the register reading from Q:
Change of the speed signal source in the measuring jobs, from constant speed to the speed read on the network:
Send values from SmartCheck to Q:
​In the above window, you should mark what values and statuses you want to send.
In this example, we are sending the vibration velocity value and the status of diagnostic indicator.
In the configuration, you must provide the initial register from which the values will be written.
The first register contains the configuration version, enter the configuration number in this register (in this case 1) in the PLC program:
If the configuration number does not match, SmartCheck will report an error.
Each change in configuration results in increasing the number by one.
The second register contains the communication status and the third is the device status.
The data we want to send begins from the fourth register.
Function check:
File name:
Description:
Q03UDV_QJ71E71
GX Works 2 Sample project
    • FAG Smart Check + ICONICS Connection Configuration
      This article describes how to connect FAG Smart Check with ICONICS using OPC UA protocol FAG Smart Check Configuration Enter IP Address of Fag in browser and log in Click "Configuration", expand "Communication channels" and click "Add" button to ...
    • Connection between E1000 and FX5 via MC Protocol
      This document describes how to establish communication between the E1000 HMI and the iQ-F controller. Summary: The MC protocol is implemented in the E1000, which allows us to connect to multiple Mitsubishi Electric devices. MC Protocol is an open ...
    • Smart check - FAG - Configuration and settings [VIDEO]
      This article contains two videos where you can learn about smart check configuration and settinigs. Part 1 Part 2:
    • PLC and PC communication via SLMP Protocol
      Overview of document Overview of PC and PLC communication via SLMP The purpose of this document is to provide simple solution for PC and PLC communication via SLMP. A the beginning, there will be presented how to set communication parameters in GX ...
    • SLMP connection with robot. Sending global and status variables to SLMP Client
      FR series robot (CR 800 controllers) have additional option of SLMP communication server implemented as standard. This enables to obtain several data from robot controller without complex configuration. With additional configuration there is ...
