INV - FR-E800 - Positioning over Profinet - iQ-R
This article describes how to positioning in FR-E800 inverters over Profinet
1. Introduction
The frequency inverters of the FR-E800EPB series are mainly intended for network control. This article describes the method of positioning the system using the Profinet network.
The FR-E800E inverters have two digital inputs (DI0 and DI1) to which the required functions can be assigned.
Before use check digital input logic
The frequency inverter of the FR-E800EPB series can be extended with virtual inputs and outputs when using the user telegram 102.
2. Block description, variable assignments
Function block
The following example shows the function block for controlling the FR-E800EPB frequency inverter via Profinet. The block has 16-bit control and status words, Input Commnad / Inverter Status, Input Command Extended / Inverter Status Extended, Setpoint and ActualValue words.
Control and status word
The control and status words are not editable, their syntax is shown below:
Bit
Control Word
Status Word
0
ON/OFF
Ready To Switch On
1
Coast Stop
Ready To Operate
2
Quick Stop
Operation Enabled
3
Enable Operation
Fault Present
4
Coast Stop Activated
5
Freeze Ramp
Quick Stop Activated
6
Enable Setpoint
Switching On Inhibited
7
Fault Acknowledge
Warning Present
8
9
Control Requested
10
Control By PLC
11
Target Torque
12
Direction Selection
13
Start HPR or Positioning
14
15
Input Command / Inverter Status (Extended)
The additional words Input Command / Inverter Status (Extended) are words with which it is possible to extend the functionality of the inverter with additional virtual digital inputs.
Inverter Status / Control Input Command - 20489
Bit
Inverter status
0
RUN
1
During Forward Rotation
2
During Reverse Rotation
3
RH
Up to Frequency
4
RM
Overload alarm
5
RL
0
6
JOG
FU
7
Second Function Selection
ABC
8
Terminal 4 Input Selection
0
9
Safety Monitor Output 2
10
MRS
0
11
0
12
RES
0
13
0
14
0
15
Fault Occurrence
Inverter Status / Control Input Command (Extended) - 20488
Bit
Inverter Status
0
NET X1
NET Y1
1
NET X2
NET Y2
2
NET X3
NET Y3
3
NET X4
NET Y4
4
NET X5
Setpoint and Actual value
Below are the words Setpoint and Actual value available in the inverter, to which the user can assign a function used in the program.
Setpoint
No
Parameter Number
Name
PNU
Access
1
1320
Target Position
24698
607Ah
R/W
2
1321
Profile Velocity
24705
6081h
R/W
3
1322
Profile Acceleration
24707
6083h
R/W
4
1323
Profile Deceleration
24708
6084h
R/W
5
1324
Inverter Reset
20482
5002h
R/W
6
1325
Homing Method
24728
6098h
R/W
7
1326
Homing Speed
24729
6099h
R/W
8
1327
Homing Acceleration
24730
609Ah
R/W
9
1328
20489
5009h
R/W
10
1329
20488
5008h
R/W
Actual Value
No
Parameter Number
Name
PNU
Access
1
1330
Actual Position
24676
6064h
R
2
1331
Velocity Actual Value
24644
6044h
R
3
1332
Velocity Demand
24643
6043h
R
4
1333
Error Code
24639
603Fh
R
5
1334
Inverter Status
20489
5009h
R/W
6
1335
20488
5008h
R/W
7
1336
Safety Input Status
20992
5200h
R
3. Controlling the frequency converter via the Profinet network using the positioning function
Inverter configurations:
Homing execution:
In the first step, select the homing method from among the available:
Then it is required to define the homing speed and the acceleration and deceleration ramps:
24729 (6099h) Homing speeds
24730 (609Ah) Homing acceleration
Make sure that the RH, RM, RL or JOG signals are turned off
Switch on the inverter according to the diagram below
S0 After power supply
Control word
Status word
Bit 10
1
Bit 6
1
Bit 5
1
Bit 0
0
Bit 6
1
Bit 1
0
Bit 2
0
S1 Switching on inhibited
Control word
Status word
Bit 10
1
Bit 6
0
Bit 5
1
Bit 0
1
Bit 6
1
Bit 1
0
Bit 0
0
Bit 2
0
Bit 1
1
Bit 2
1
S2 Ready for switching on
Control word
Status word
Bit 10
1
Bit 6
0
Bit 5
1
Bit 0
1
Bit 6
1
Bit 1
1
Bit 0
1
Bit 2
0
Bit 1
1
Bit 2
1
S3 Operation
Control word
Status word
Bit 10
1
Bit 6
0
Bit 5
1
Bit 0
1
Bit 6
1
Bit 1
1
Bit 0
1
Bit 2
1
Bit 1
1
Bit 2
1
Bit 3
1
Then drive using the variable Bit 13 in the frequency inverter control word described as Start HPR or Positioning.
Drive to the demand position
In order to drive to a given position, in the first step, set the value of the RH bit (b_RH) to a high state.
Then, switch on the inverter according to the diagram below
Control word
Status word
Bit 10
1
Bit 6
1
Bit 5
1
Bit 0
0
Bit 6
1
Bit 1
0
Bit 2
0
Control word
Status word
Bit 10
1
Bit 6
0
Bit 5
1
Bit 0
1
Bit 6
1
Bit 1
0
Bit 0
0
Bit 2
0
Bit 1
1
Bit 2
1
Control word
Status word
Bit 10
1
Bit 6
0
Bit 5
1
Bit 0
1
Bit 6
1
Bit 1
1
Bit 0
1
Bit 2
0
Bit 1
1
Bit 2
1
S3 Operation
Control word
Status word
Bit 10
1
Bit 6
0
Bit 5
1
Bit 0
1
Bit 6
1
Bit 1
1
Bit 0
1
Bit 2
1
Bit 1
1
Bit 2
1
Bit 3
1
