This article contains the sample display with functionality of showing all properties with their values of any selected asset from the asset tree with possibility to change it's value
With this solution you select interesting asset in Asset Navigator and on the left side of the display you get full path of this asset with propertis count and full list of dynamic read of this asset properties with possibility of changing it vales.
The functioanlity is pretty common as in data explorer but using this solution you have possibility of customize it.
