Iconics Suite - Using Clone Dynamic with Smart Symbols [Iconics syntax]
This article show special syntax that have to be use in Smart Symbol to use it with Clone Dynamic
This article focus on non "zero" base asset name - we will use the asset that their numbering starts from "1"
Prepare Assets
- prepare assets as on the illustration below
Create Smart Symbol
- create simple Smart Symbol contains only rectangle and Process Point with one Smart Property : AssetPath (StringDataSource)
Use Clone Dynamic
- put your Smar Symbol in the stack panel and add Clone Dynamic function to you symbol
- configure instantiation base on the asset count
Configure Smart Symbol properties syntax
- syntax is more complex cause we will show how to increment in Clone Dynamic starting from 1 not from 0
- Exact syntax in Expression editor:
- configure expression for binded dataSource of Process Point
You can find the sample display in attached file
