To read remote input or set remote output of CC Link IE Field remote IO station, you need to initialize it. There are two ways to do that:
1. Using remote IO parameters
2. Using PLC program
Initialization using remote IO parameters
Parameter of remote IO station decides which initialization method you need to perform. Remmote IO parameters can be found in CC Link IE Field configuration window. Click on chosen IO module:
PPM -> Online -> Paremeter Processing of Slave Station.
Initialization method can be changed using
Initial operation setting parameter. This parameter can have two values, which means:
- 0: with initial processing - this setting requires additional initialization from PLC program
- 1: without initial processing - this setting do not require additional initialization
To write parameter to IO station, you have to choose
Parameter write, prepare parameter pack (parameters cannot have non value). At the end you have to click
Execute Parameter Processing.
PLC Initialization using PLC program
In PLC program you need to read status of
Initial processing request flag (RWr0.b8)
. When module will be ready, you have to set
Initial processing completion flag (RWw0.b8).
Program example, with belowed CC Link register mapping:
CC Link |
CC Link |
PLC |
PLC |
Od |
Do |
Od |
Do |
RWr0 |
RWr13 |
W100 |
W113 |
RWw0 |
RWr13 |
W200 |
W213 |
Program:
