MAPS agents programs example PL
Artykuł zawiera przykładowe programy obsługi agentów w programie MAPS
This project contains example programs of agents in MAPS
Przykładowe programy
Odczyt/zapis agentów z pozycji C# (pojedyncze agenty)
Biblioteki
using VIZNET.Shared.DataElements.Engine;
Definicja klasy
#region agentControlClass and declare agentControlClass
public class agentsControlClass
public DataElementCollection agentsCollection = DataElementEngine.NewDataElementCollection();
public DataElementCollection collectionReturned = DataElementEngine.NewDataElementCollection();
public MethodReturnInfo write_info;
public MethodReturnInfo read_info;
agentsControlClass agentsControl = new agentsControlClass();
#endregion
Funkcja zapisu agentów
#region agentWrite
private void agentWrite(string agent_name, object agent_value)
DataElement input_agent = DataElementEngine.NewDataElement("Adroit." + agent_name);
input_agent.Value = agent_value;
agentsControl.agentsCollection.Clear();
agentsControl.agentsCollection.Add(input_agent);
try
agentsControl.write_info = MyConnection.UpdateDataElements(agentsControl.agentsCollection);
catch (Exception ex)
MessageBox.Show("Error: " + ex.ToString());
#endregion
Funkcja odczytu agentów
#region agentRead
private DataElement agentRead(string agent_name)
try
agentsControl.read_info = MyConnection.ReadDataElements(agentsControl.agentsCollection);
return (agentsControl.read_info.ReturnObject as DataElementCollection)["Adroit." + agent_name];
#endregion
Odczyt/zapis agentów z pozycji C# (kolekcja agentów)
Biblioteki
#region Read Agent Server Collection
private DataElement[] agentCollectionRead(string[] agentsName)
int elements = agentsName.Length;
DataElement[] dataElements = new DataElement[elements];
DataElement[] returnDataElements = new DataElement[elements];
for (int i = 0; i < elements; i++)
dataElements[i] = DataElementEngine.NewDataElement("Adroit." + agentsName[i]);
try
DataElementCollection dec = DataElementEngine.NewDataElementCollection();
foreach (DataElement de in dataElements)
                    dec.Add(de);
                MethodReturnInfo info = MyConnection.ReadDataElements(dec);
                if (!info.Success)
                    MessageBox.Show("Error reading element, the error was: " + info.ReturnInformation);
                else
                    DataElementCollection returnDEC = info.ReturnObject as DataElementCollection;
                        returnDataElements[i] = returnDEC["Adroit." + agentsName[i]];
                MessageBox.Show("An exception occurred: " + ex.ToString());
            return returnDataElements;
#endregion
#region Write Agent Server Collection
private void agentCollectionWrite(DataElement[] dataElements)
int elements = dataElements.Length;
if (elements > 0)
   try
dec.Add(dataElements[i]);
MethodReturnInfo info = MyConnection.UpdateDataElements(dec);
if (!info.Success)
   MessageBox.Show("Error updating element, the error was: " + info.ReturnInformation);
else
   MessageBox.Show("Successful update");
#endregion
Przykład użycia funkcji – Read Agent Collection
private void button_readAgentCollection_Click(System.Object sender, System.EventArgs e)
string[] agentsName = new string[4];
agentsName[0] = "systeminfo.second";
agentsName[1] = "FX5_D0.value";
agentsName[2] = "FX5_D6_D7.value";
agentsName[3] = "FX5_D10FLOAT.value";
DataElement[] odczytaneDane = agentCollectionRead(agentsName);
DataElement returnDE = odczytaneDane[0];
DataElement returnD0 = odczytaneDane[1];
DataElement returnD6 = odczytaneDane[2];
DataElement returnD10 = odczytaneDane[3];
MessageBox.Show("The value of: " + returnDE.Name + " is: " + returnDE.Value.ToString());
MessageBox.Show("The value of: " + returnD0.Name + " is: " + returnD0.Value.ToString());
MessageBox.Show("The value of: " + returnD6.Name + " is: " + returnD6.Value.ToString());
MessageBox.Show("The value of: " + returnD10.Name + " is: " + returnD10.Value.ToString());
Przykład użycia funkcji – Write Agent Collection
private void button_writeAgentCollection_Click(System.Object sender, System.EventArgs e)
    int D0_value = int.Parse(tb_D0.Text);
    int D6_value = int.Parse(tx_D6.Text);
    decimal D10_value = decimal.Parse(tb_D10.Text.Replace(".", ","));
    DataElement[] dataElements = new DataElement[3];
    dataElements[0] = DataElementEngine.NewDataElement("Adroit.FX5_D0.value");
    dataElements[0].Value = D0_value;
    dataElements[1] = DataElementEngine.NewDataElement("Adroit.FX5_D6_D7.value");
    dataElements[1].Value = D6_value;
    dataElements[2] = DataElementEngine.NewDataElement("Adroit.FX5_D10FLOAT.value");
    dataElements[2].Value = D10_value;
    agentCollectionWrite(dataElements);
Ukrycie ramki okna
Należy wkleić po inicjalizacji obiektów
Kod ukrywający ramkę okna głównego
((Form)((UserControl)VIZNET.UI.Runtime.ObjectManager.GetInstance().VIZNETMain).Parent).FormBorderStyle = FormBorderStyle.None;
    • MAPS - Logging and extract data to CSV
      This manual shows how to logging data during the process and extract this logs to CSV after finishing process. Every process is saved to other CSV file. "Copyright © Mitsubishi Electric Europe B.V. IMPORTANT ! These Function Blocks are demo versions ...
    • ME96 and MAPS connected by Modbus RTU
      This document shows how to connect electronic multi-measuring instrument ME96-MB to MAPS SCADA via Modbus RTU. Connection is using MOXA 1130 converter RS485 to USB Configuration MOXA converter Searching MOXA in device manager   The most important ...
    • ME96 and MAPS connected by Modbus TCP_IP
      This document shows how to connect electronic multi-measuring instrument ME96-MB to MAPS SCADA via Modbus TCP/IP Configuring Local Network Parameters Set static address IP on local network     MAPS Config Editor  Install new driver First install new ...
    • Iconics Suite - Installation of GENESIS64 Basic and Advanced in Secured and Unsecured mode
      Instruction bellow will help you step by step with installation of ICONICS in unsecured mode and secured mode version 10.97.2 + Critical Rollup CFR2 Installation of GENESIS64 Basic and Advanced will be also highlighted Installation of GENESIS64 Basic ...
    • DIGITAL: Maps driver list
      Summary: In the attachment you can download a sheet in which you can find information about the drivers for Scada Adroit Maps.
