ME96 and MAPS connected by Modbus TCP_IP
This document shows how to connect electronic multi-measuring instrument ME96-MB to MAPS SCADA via Modbus TCP/IP
Configuring Local Network Parameters
Set static address IP on local network
MAPS Config Editor
Install new driver
First install new driver in MAPS Config Editor.
Run MAPS Config Editor -> Configuration-> Agent Server ->Driver Configuration
If new open window is empty, choose path to folder with drivers by clicking button […]
Default path to folder with drivers is folder where MAPS is instelled:
C:\Program Files(x86)\Adroit Technologies\Adroit\Drivers
After that choose Modbus Ethernet Driver
Add new device
After install driver, add new device under this protocol driver.
Right click on Modbus Ethernet Driver and Add device
Enter the device name:
Configure new device
After add new device, configure it.
In basic options set the PLC Details as below:
After that click Advanced and set advanced parameters.
Most important parameter is disable “Address 255 Padding Required”. Default this parameter is ON.
MAPS Designer
Add new agent
Add new Analog Agent in Open Configurator and Scan it.
Always add 400001 to address!!!
For example when read address 768 in Agent set address as 400769.
Testing
Open DATASCOPE and see sending and reading frame
Check value in Analog Agent
1DB in hex = 475 in dec so value is correctly!
