Modbus configuration
Modbus RTU configuration in MR-JE-A and MR-J4-A
This document describes connection and configuration of MR-JE and MR-J4 using MODBUS RTU.
Wiring for MR-JE-_A
Up to 32 axes Of servo amplifiers can be operated and controlled on one bus.
Half duplex wiring
Wire the system as shown below.
Note:
  1. Connector set MR-J3CN1 (3M or equivalent)
    1. Connector: 10150-3000PE
    2. Shell kit: 10350-52F0-008
  2. Connect TRE and RON on the last axis.
  3. The total extension length should be 30 m or shorter in a low-noise environment
  4. When a Modbus-compatible controller does not have a termination resistor, terminate the wire ends with a resistor of 150 Ω
Full duplex wiring
Note:
Wiring MR-J4-_A_-RJ
Half duplex wiring
Full duplex wiring
Communication configuration
FOR MR-JE-_A
FOR MR-J4-_A_-RJ
Sample paramter setting
For basic communication you need to set parameters:
  1. PC70 – station number
  2. PC71 –
    1. _ _ _ x – communication protocol selection
    2. _ _ x _ - communication baud rate selection
  3. PF45 – _ _ _ x -  communication parity selection
For operating input devices via the MODBUS-RTU communication:
PC71 – _ 0 _ _
PA01 – _ _ _ 6 or _ _ _ 7 - control mode
For operating input devices via DI:
  1. PC71 – _ 1 _ _
  2. PA01 –
    1. from _ _ _ 0 to _ _ _ 7 for MR-JE-_A
    2. from _ _ _ 0 to _ _ _ 8 for MR-J4-_A_- RJ
Related manuals
MR-J4-_A_-RJ SERVO AMPLIFIER INSTRUCTION MANUAL (Modbus-RTU Protocol)
MR-JE-_A(MODBUS_RTU_PROTOCOL)
Video about Modbus RTU settings:
https://eu-assets.contentstack.com/v3/assets/blt5412ff9af9aef77f/blt72ff72a5da518319/6172426918e0bf0f0a30b695/0fdee94c-fb10-11e5-ae6c-b8ac6f83a177_MR-JE_MODBUS_POL.wmv
