GX Works3 - Function block for rounding float numbers with variable amount of significant numbers
This article contains GX Works3 function block for rounding float numbers with variable amount of significant numbers.
"Copyright © Mitsubishi Electric Europe B.V.
This function block return rounded FLOAT number, rounded with mathematical convention of rounding numbers. Selecting amount of significant numbers is possible using second input.
Input/Output
Data Type
Description
i_eNumber
FLOAT
Number to be rounded
i_iSignificantNum
Word [Signed]
Amount of significant numbers
EROUND
FLOAT
Rounded number
Selecting amount of numbers after the dot is possible using i_iSignificantNum input. When „0” is inputted, number will be rounded to integer part:
6.3864 -> 6.0000
When i_iSignificantNum is set to another number, for example „2”:
6.3864 -> 6.3900
