PLC uruchamia programy robota
PLC loads robot’s programs by control register
Robot can be controlled by general PLC or other system. This article shows how to easly run any robot’s program by one control register and its deferent values.
Komendy Tool, Oadl są zachowane zarówno przy wywołaniu programu instrukcją CallP, jak i po powrocie do programu głównego. Czyli można ich użyć jeden raz w jakimś programie i wartość zostanie aktywna cały czas.
Komendy  Accel, Spd, Ovrd, JOvrd nie zachowują wartości z poprzedniego programu i w nowym programie są zresetowane do wartości domyślnych (czyli maksymalnych). Zatem te komendy każdorazowo powinny być użyte w wywoływanych programach (i głównym).
I Introduction
This method allows to run robot programs by using one PLC control register. Robot as default runs one main control program (named MAIN) which can load any other defined program by Callp command. MAIN program receives a value from control register and compares it with values defined in Select…Case function. If the value matches to one of defined then the specified program is executed.
Example
PLC control register = 100   ->   Robot runs: INIT
PLC control register = 200   ->   Robot runs: SEQ1
PLC control register = 300   ->   Robot runs: SEQ2
PLC control register = other   ->   Robot runs: nothing
 Robot programs - example:
All program’s names in this document are exemplary and can be changed to any other.
Also signals numbers are exemplary and can be changed to any other. In this solution general I/O signals (area 0-63) are used. To run these functions by a network (e.g. Profinet, CC-Link, etc.) – mount a network card, configure it and set signals from area 2000 or 6000. To run these functions in Q or R type robot (integrated with Mitsubishi Electric PLC platform) set signals from area 10000.
II Program codes
Sample codes to copy are at the end of the article
II.1 Sample code of MAIN control program
Control register is read by M_Inw(16) and rewrited to mProgram variable.
Line M_Outw(16)=M_Inw(16) can be used as a confirmation of received value back to PLC (and generally as a communication working confirmation).
Select…Case function compares a value from control register and activate a Case if the value matches to Case value.
Additional information
Callp instruction switches program on specified Slot to called one, for example: Main program is switched to Init program after Callp “Init” instruction.
Called program by Callp instruction is performed only one time, then the previous program is loaded again.
Do not insert any movement command to this program. Movements and other application command insert to programs run by CallP instruction.
II.2 Sample code of first called program (INIT)
This is an example of application program (movements, etc.).
M_Outw(16) commands are introduced here to send out to PLC information of performed steps. Control value was “100”, confirmation values are respectively “101”, “102”, etc.
PLC program, right after receiving confirmation that called program is executed, should change its value (e.g “100” -> “0” or “100” -> “101”). Otherwise the program will be run once again, right after ending.
II.3 Sample code of second called program (SEQ1)
M_Outw(16) commands are introduced here to send out to PLC information of performed steps. Control value was “200”, confirmation values are respectively “201”, “202”, etc.
PLC program, right after receiving confirmation that called program is executed, should change its value (e.g “200” -> “0” or “200” -> “201”). Otherwise the program will be run once again, right after ending.
III Parameters
III.1 Slot Table
Set below parameters to load the MAIN program to Slot 1 for execution:
1 Open Slot Table parameters
2 Select first Slot
3 Click Set… and confirm next window about reading program list
4 In Slot Table Parameter Setting chose desired program
5 Set condition to START (or ALWAYS)
6 Write parameters and restart robot
III.2 General control
Set general control signals
No needed if the MAIN program is executed in ALWAYS mode
By these signals control the Main program.
After robot power on, set Operation Enable signal and then Start signal. The Main program on Slot 1 will start running.
IV Operation
When MAIN program is running, send right control value to execute desired application program.
When robot confirms the program execution by its output register M_Outw(…) immediately change the PLC control value to other one.
If the control value is 0 or any other than values defined in Select…Case function, robot will not load any program -the only working program will be MAIN.
Sample codes
1. Main
'Main control program - example
'No movement commands
mProgram=M_Inw(16)    'control value received from PLC
M_Outw(16)=M_Inw(16)  'confirmation of received value to PLC
Select mProgram
Case 100            'action wher control value "100"
   CallP "INIT"     'INIT program start
Break
Case 200            'action wher control value "200"
   CallP "SEQ1"     'SEQ1 program start
Break
Case 300            'action wher control value "300"
   CallP "SEQ2"     'SEQ2 program start
Break
End Select
End
2. Process program
'Sample
M_Outw(16)=101  'INIT program start, information to PLC
Mov P1
Mov P2
M_Outw(16)=102  'INIT program end, information to PLC
End
