Setting robot additional mechanism (external)
The article describes how to set and program robot additional servo axis as a separate mechanism (for example rotary table). The detailed information can be found in:
ADDITIONAL AXIS FUNCTION INSTRUCTION MANUAL (BFP-A3504)
The article do not describe how to wire a servo drive. Please use a separate user manual for servo drives.
Introduction
Basic equipment
Hardware:
  1. Servo set: Mitsubishi Electric MR-J3-B or MR-J4-B series (amplifier+motor)
  2. Serwo battery: MR-J3BAT (connect to servo amplifier)
  3. Fiber cable: MR-J3BUS3M
Software:
  1. RT Toolbox3
  2. MR Configurator2
Wiring
Connect the fiber cable to AXIS connector in controller and CN1A in serwo amplifier. Follow the pictures below.
Servo settings
Address setting
Servo settings in MR Configurator2
Connect directly to serwo amplifier by USB mini cable. Run MR Configurator2 and set a parameter in picture below.
I f you don’t have emergency button connected then deactivate Forced Stop function. Otherwise the emergency error will occur.
Anyway it is recommended to connect emergency wiring from the beginning of work (details in ROBOT ADDITIONAL AXIS FUNCTION MANUAL or SERWO MANUAL).
If a robot is stopped by Emergency Stop function, the additional robot axes will be also stopped. The signal is sent by fiber cable.
Write the parameters and perform servo restart.
Robot parameters
1. Open Robot additional axis parameters in RT Toolbox3.
2. AXUNUM parameter set to “1” (one additional mechanism existance).
3. Select first line in a table (first additonal servo)
4. Click Set... button
Additional axis 1 parameter window will appear. Set basic settings.
Basic settings:
AXMENO – mechanism number (1 – robot, 2 – additional mechanism); set 2 for rotary table
AXJNO – axis number in a specified mechanism; set J1 axis for rotary table (first axis in mechanism no 2)
AXGRTN, AXGRTD – insert mechanical gear ratio of your rotary table
AXUNIT – choose unit system; set 0:deg for rotary table
MEJAR – insert low and hight movement limits. Watch out the limitation for movements limits min/max values (see the manual)
AXSPOL – set rotation direction
The other parameters can be left default.
Write the parameters and perform robot restart.
The additional axis now should be recognized. In servo display "b01" message should appear.
Origin settings
At first running the origin settings must be done for the additional axis.
Move the additional mechanism (rotary table) to the position where zero will be set and perform origin setting. Follow the picture below.
Now the additional mechnism is ready for usage.
JOG in additional mechanism
Use a robot Teaching Box. Switch to mechanism number 2 (2:USER).
And like with robot: perform SERVO ON and use +/- buttons for mechanism control.
Programming
Principles:
Additional mechanism is controlled from separate program (multitasking mode)
Each program must start with GetM command (GetM 1 for robot program, GetM 2 for mechanism program)
Data exchange between programs is performed by external (global) variables (use predefined M_00, M_01,…, P_00, P_01,… or user defined)
Programs example:
'pr1 main program (robot arm)
GetM 1
M_01=0      'global variable 1
M_02=0      'global variable 2
If M_Svo(1)=0 Then Servo On
If M_Run(2)=0 Then XRun 2,"pr2"       'run Program 2 for additional mechanism
Wait M_Run(2)=1
mov p1
mov p2
dly 0.5
m_01=1         'add mech movement permission
wait m_02=1        'wait for add mech movement end
mov p1
m_02=0
end
'pr2 second program (additional mechanism)
GetM 2
If M_Svo(2)=0 Then Servo On
wait m_01=1        'wait for movement permission
m_01=0
mov p1
mov p2
mov p1
m_02=1        'end movement confirmation
end
    • Robot simulation with additional axis - quick start guide
      This document shows how to make the robot simulation with addtional axis movement. This function can be used to move any objects from the layout. "Copyright © Mitsubishi Electric Europe B.V. IMPORTANT ! These Function Blocks are demo versions that ...
    • Iconics Genesis V11 - MELFA connection + Asset Builder - gathering data from an iQ-R integrated robot (R16RTCPU)
      This article shows how to directly connect Genesis V11 with MELFA robots running on iQ-R integrated R16RTCPU controllers. It also describes how to automatically generate assets and displays with robot data using the Asset Builder. Robot configuration ...
    • Sample GOT screens for robot control (FR Series, CR800-D), Full Project
      An official sample GOT2000 project for robot FR Series (CR800-D controller) controlling and monitoring System configuration: Project contains follwing screens: Robot operation Position Edit JOG control HAND control Variable edit Load level monitor ...
    • Servo sizing tool - Motorizer
      This article describes functionality of Motorizer - servo selection tool Motorizer introduction Motorizer is a free software designated for selecting proper servomotor to the application. It includes most common types of load mechanisms like: Ball ...
    • Robot error information on GOT
      Document describe how to monitor error code using GOT. 1. Comminication settings Establish standard ethernet communication between robot and GOT. Setup communication driver for robot. We use Extended memmory for data transfer. Refresh time of data is ...
