This manual shows the wiring of robot's arm and connectors.
RV-2FR
Pneumatics
1E-VD02E 1E-VD01E
Products
Digital inputs products
1S-HC30C-11
Digital outputs products
1E-GR35S
RV-4/7/13/20FR
Pneumatics
RV-4/7FR pneumatics products
1F-VD01E-02 1F-VD02E-02 1F-VD03E-02 1F-VD04E-02
RV-13/20FR pneumatics products
1F-VD01E-03 1F-VD02E-03 1F-VD03E-03 1F-VD04E-03
1F-HC35S-02
1F-GR35S-02
Cable sets
1F-HB01S-01 1F-HB02S-01 1F-HA01S-01 1F-HA02S-01 268039
Plug sets
268039 268040 278390
RH-3/6/12/20FR
Pneumatics
RV-3/6FR pneumatics products
1F-VD01E-01 1F-VD02E-01 1F-VD03E-01 1F-VD04E-01
RV-12/20FR pneumatics products
1S-VD01E-01 1S-VD02E-01 1S-VD03E-01 1S-VD04E-01
1F-HC35C-01 1F-HC35C-02 164815
1F-GR60S-01 RV-S Hand OUTPUT connector
Pulled outside the arm
1F-UT-BOX 1F-UT-BOX-01
Plug set
273182
Internal wiring set
1F-HS604S-02 1F-HS408S-01 1F-HS408S-02 1F-HS604S-01 1F-HS604S-02
RV-35/50/80FR
Machine
cable
7m
Fixed
with robot included
3
pieces
machine
cable
set (power
supply
and signal
cables – one set of machine cables consist
of three
cables)
Longer machine cables as option:
Product
ID
Model
Name
Description
700805
1F-07LUCBL-44
Machine
Cable 7m for CR860, flexible
700806
1F-12LUCBL-44
Machine
Cable 12m for CR860, flexible
700807
1F-17LUCBL-44
Machine
Cable 17m for CR860, flexible
700808
1F-22LUCBL-44
Machine
Cable 22m for CR860, flexible
700802
1F-12UCBL-44
Machine
Cable 12m for CR860, Standard
700803
1F-17UCBL-44
Machine
Cable 17m for CR860, Standard
700804
1F-22UCBL-44
Machine
Cable 22m for CR860, Standard
Pneumatics
There is no dedicated valve product for this series. Air control is prepared by user. On robot arm there are two air pipe hoses, as shown below.
Hand input cable
Cable
1F-HC2000S-44
(700777)
Hand output cable
Cable
1F-GR2000S-44
(700776)
Hand Ethernet Cable
Cable
1F-LAN2000-44
(700778)
More details about setup of this robot available on attachment.
