Mitsubishi library for SISTEMA
This document inform how to instal SISTEMA library and what products are included in current version of library.
PL: Dokument ten opisuje sposób instalacji biblioteki SISTEMA oraz pokazuje listę produktów występujących w aktualnej bibliotece.
1     Downloading the library from website
Actual library is available on this website:
https://www.dguv.de/ifa/praxishilfen/practical-solutions-machine-safety/software-sistema/sistema-bibliotheken/index.jsp
1.1    Right click on [Mitsubishi Electric Europe B. V.].
1.2    Sign in to your MyMitsubishi account. Remember to accept necessary Cookies before you login. Signing in will start downloading of library automatically.
1.3    If you do not have account – register for MyMitsubshi service to have access to plenty of facilitie
2     Import the library to SISTEMA
2.1     Move downloaded file in SLB format file into the folder where SISTEMA is installed: e. g. [C:\Users\User\Documents\SISTEMA\Libraries]
2.2    Run SISTEMA and import Mitsubishi Library  - click on [Library], then click on [Add local Library…], choose [MITSUBISHI_ELECTRIC_LIB_EN] and click on [Open].
2.3    In [Libraries] section left click on [MITSUBISHI_ELECTRIC_LIB_EN].
2.4    Expand Subsystems section - you can see contents of Mitsubishi library.
3     Actual list of Mitsubishi products avaliable in SISTEMA’s library.
3.1    Controllers.
3.1.1  MELSEC IQ-R.
Safety CPU:
MELSEC IQ-R - Safety CPU: R08SFCPU + R6SFM
MELSEC IQ-R - Safety CPU: R08SFCPU + R6SFM („04” and „05”)
MELSEC IQ-R - Safety CPU: R08SFCPU + R6SFM („03” or earlier and „04” or earlier)
MELSEC IQ-R - Safety CPU: R16SFCPU + R6SFM
MELSEC IQ-R - Safety CPU: R16SFCPU + R6SFM („04” and „05”)
MELSEC IQ-R - Safety CPU: R16SFCPU + R6SFM („03” or earlier and „04” or earlier)
MELSEC IQ-R - Safety CPU: R32SFCPU + R6SFM
MELSEC IQ-R - Safety CPU: R32SFCPU + R6SFM  („04” and „05”)
MELSEC IQ-R - Safety CPU: R32SFCPU + R6SFM („03” or earlier and „04” or earlier)
MELSEC IQ-R - Safety CPU: R120SFCPU + R6SFM
MELSEC IQ-R - Safety CPU: R120SFCPU + R6SFM („04” and „05”)
MELSEC IQ-R - Safety CPU: R120SFCPU + R6SFM („03” or earlier and „04” or earlier)
Safety I/O:
MELSEC IQ-R - Safety I/O: NZ2GFSS2-32D
MELSEC IQ-R - Safety I/O: NZ2GFSS2-32D + NZ2EXSS2-8TE
MELSEC iQ-R – Safety I/O: NZ2GFSS2-8D
MELSEC iQ-R – Safety I/O: NZ2GFSS2-8TE
MELSEC iQ-R – Safety I/O: NZ2GFSS2-16DTE
MELSEC iQ-R – Safety I/O: NZ2GS12A2-16DTE
MELSEC iQ-R – Safety I/O: NZ2GS12A2-14DT
MELSEC iQ-R – Safety I/O: NZ2GNSS2-8D
MELSEC iQ-R – Safety I/O: NZ2GNSS2-8TE
MELSEC iQ-R – Safety I/O: NZ2GNSS2-16DTE
3.1.2  MELSEC–QS.
Safety CPU:
MELSEC–QS - Safety CPU: QS001CPU
MELSEC–QS - Safety CPU: QS001CPU („1207” or earlier)
MELSEC –QS - Safety CPU: QS001CPU-K
Safety Power Supply:
MELSEC–QS - Safety Power Supply: QS061P-A1/A2
MELSEC–QS - Safety Power Supply: QS061P-A1/A2 („1205” or earlier)
MELSEC-QS – Safety Power Supply: QS061P-A1-K/A2-K
Safety I/O:
MELSEC–QS - Safety I/O: QS0J65BTS2-8D
MELSEC–QS - Safety I/O: QS0J65BTS2-4T
MELSEC–QS - Safety I/O: QS0J65BTB2-12DT
MELSEC–QS - Safety I/O: QS0J65BTB2-12DT-K
Safety Relay:
MELSEC-QS Safety Relay: QS90SR2SP-Q [Cat. 4]
MELSEC-QS Safety Relay: QS90SR2SP-Q [Cat. 3]
MELSEC-QS Safety Relay: QS90SR2SN-Q [Cat. 4]
MELSEC-QS Safety Relay: QS90SR2SN-Q [Cat.3]
MELSEC-QS Safety Relay: QS90SR2SP-CC [Cat. 4]
MELSEC-QS Safety Relay: QS90SR2SP-CC [Cat. 3]
MELSEC-QS Safety Relay: QS90SR2SN-CC [Cat. 4]
MELSEC-QS Safety Relay: QS90SR2SN-CC [Cat.3]
MELSEC-QS Safety Relay: QS90SR2SP-EX [Cat. 4]
MELSEC-QS Safety Relay: QS90SR2SP-EX [Cat. 3]
MELSEC-QS Safety Relay: QS90SR2SN-EX [Cat. 4]
MELSEC-QS Safety Relay: QS90SR2SN-EX [Cat.3]
3.1.3  MELSEC-WS.
Safety CPU:
MELSEC-WS – Safety CPU: WS0-CPU0
MELSEC-WS – Safety CPU: WS0-CPU1/3
MELSEC-WS – Safety CPU: WS0-CPU3 (Flexi Line station)
Safety I/O:
MELSEC-WS – Safety I/O: WS0-XTDI
MELSEC-WS – Safety I/O: WS0-XTIO (1 ch output with test pulses)
MELSEC-WS – Safety I/O: WS0-XTIO (1 ch output without test pulses)
Safety Relay:
MELSEC-WS – Safety Relay: WS0-4RO
3.1.4  MELSEC iQ-F
Safety Extension Module:
MELSEC iQ-F – Safety Extension Module: FX5-SF-MU4T5
MELSEC iQ-F – Safety Extension Module: FX5-SF-8DI4
3.2    Servo.
MELSERVO J3 – Safe Torque Off
MELSERVO J4 – for SLS function with motion controller Q series
MELSERVO J5/J4/JE – Safe Torque Off
MELSERVO J5-RJ/J5W – STO, SS1-t and SBC
MELSERVO J5-RJ with safety encoder combination
MELSERVO J5-RJ with standard encoder combination
MELSERVO J5-RJ – SLT
MELSERVO Functional Safety Unit MR-D30 with safety encoder combination
MELSERVO Functional Safety Unit MR-D30 with standard encoder combination
AC Servo Motor -  Functional safety motor, HK-KT/ST_WS
AC Servo Motor -  Functional safety motor, HG-KR/SR/JR_W0C
Motion Controller Q (Q17nD/DS) Series
MELSERVO Safety Logic unit MR-J3-D05
3.3    Inverter.
FREQROL A800 – Safe Torque Off
FREQROL A870-LC – Safe Torque Off
FREQROL A870 – Safe Torque Off
FREQROL A800-R2R/ELV – Safe Torque Off
FREQROL A802-P – Safe Torque Off
FREQROL A840-LC – Safe Torque Off
FREQROL D700 – Safe Torque Off
FREQROL E700 – Safe Torque Off
FREQROL E800(-E) – Safe Torque Off
FREQROL E800-SCE
FREQROL F800 – Safe Torque Off
3.4    Robot.
MELFA CR750 + Robot Safety Option (SLS/SLP)
MELFA CR750 + Robot Safety Option (STR)
MELFA CR750 + Robot Safety Option (STO)
MELFA CR800 + Robot Safety Option (STO) [Cat. 4]
MELFA CR800 + Robot Safety Option (STO) [Cat. 3]
MELFA CR800 + Robot Safety Option (SS1/SS2/SOS)
MELFA CR800 + Robot Safety Option (SLS/SLP)
MELFA CR800 + Robot Safety Option (STR)
    • CC-Link IE TSN safety communication with MR-J5G-RJ
      This document describes how to start safety communication of CC-Link IE TSN between iQ-R Safety, safety remote I/O and MR-J5G-RJ. "Copyright © Mitsubishi Electric Europe B.V. IMPORTANT ! These Function Blocks are demo versions that are only intended ...
    • User library in GX Works3
      This document describes how to create and use user libraries in GX Works 3. Creating user library Open "Export Library" window   Open "Library Detailed Setting" Public will be attached to new library Private won’t be attached to new library Editable ...
    • GOC43 - Library error issue solution
      This article explains how to deal with Codesys errors upon creating a new project when there is a newer version of Codesys installed on the computer. Example of the problem After creating a new project for the GOC43 in Codesys there is a really high ...
    • Circular Tracking using functions blocks (MELFA Basic VI)
      The article presents a library for supporting circular tracking function. If you are interested in linear tracking applications, refer to the article below: Tracking using functions blocks (MELFA Basic VI) "Copyright © Mitsubishi Electric Europe B.V. ...
    • Safety WS RS232 connection cable
      This project contains information about connecting programming cable to Safety WS Connection       Programming socket (RS232) Safety WS has got M8 connector for programming Pin assigment is described on picture below:   Plug/socket PIN Signal      1 ...
