This article describes how to use dedicated function block to control servo MR-J5-G or MR-JET-G via CC-Link IE Field Basic. Attached to this article you can find sample projects for iQ-F and iQ-R PLCs and library files with detailed documentation. ...
This article describes how to startup motion system base on FX5-SSC-G module. Article base on MR-J5-G but in the same way MR-JET-G can be used. PLC configuration Creating new project Startup GX Works3 and create new project. Select the model of the ...
This article contains description of two function blocks for iQ-F CPU that convert LREAL to REAL data type and REAL to LREAL data type 1. LREAL2REAL - function block that converts two-element array of double words (unsigned) to float data type In/Out ...
