This article describes connection between GOT 2000 and GT Designer3 over RCPU with RJ71EN
Ten artykuł opisuje połączenie pomiędzy panelem GOT 2000 i oprogramowaniem GT Designer3 poprzez sterownik RCPU z modułem RJ71EN
1. PC
-> RCPU -> RJ71EN -> GOT
In this case PC will be connected to built-in ethernet port on RCPU and GOT will be connected to RJ71EN.
RCPU: 192.168.3.39
Network No. 2 Station No. 1
RJ71EN: 192.168.3.40
Network No. 1 Station No. 1
Routing: Network No. 2 Station No. 1 -> Network No. 1
1.1 Network configuration
Firstly you need to configure ethernet built-in port and module. You need to set:
- Two different IP adresses
- Enable communications by Network No./Station No.
- Set Network No./Station No.
- Add MELSOFT connections
So for built-in port:
And for ethernet module:
1.2 Routing configuration
Giving that PC is connected to Network No. 2 we will be routing this network to Network No. 1 (network with GOT):
1.3 Driver configuration
In driver configuration you need to put network number of module that GOT is connected to:
1.4 GT Designer3 communication configuration
2. PC
-> RJ71EN -> RCPU-> GOT
In this case PC will be connected to RJ71EN and GOT to built-in ethernet port of RCPU
RCPU: 192.168.3.39
Routing: Network No.1 Station No. 1 -> Network No.2
In this case we will be routing Network No. 1 into Network No. 2:
